Knowledge Base Article
Why does the system report completion timeout error and hang up when using Multi Channel DMA FPGA IP for PCI Express*?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 23.4 and earlier, you might observe completion timeout error and system hang up when using Multi Channel DMA FPGA IP for PCI Express* when MCTP option is enabled in Basic Input/Output System (BIOS).
Resolution
To work around this problem, disable the MCTP option in BIOS and restart the system.
This problem is scheduled to be fixed in a future release of the Quartus® Prime Pro Edition Software.
Updated 1 month ago
Version 2.0
