Knowledge Base Article
Why does the Synopsys VCS* simulator fail when simulating the F-Tile Triple-Speed Ethernet Intel® FPGA IP Design Example?
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software version 23.2 and 23.3, Synopsys VCS* simulator fails when targeting the F-Tile Triple-Speed Ethernet Intel® FPGA IP Design Example.
Resolution
To work around this problem, append the simulation switch "-debug_region=encrypt" in USER_DEFINED_ELAB_OPTIONS in the generated Synopsys VCS* simulation script (run_vcs.sh) for the F-Tile Triple-Speed Ethernet Intel® FPGA IP Design Example.
This problem is fixed in version 23.4 of the Intel® Quartus® Prime Pro Edition Software.
Updated 2 months ago
