Knowledge Base Article
Why does the Stratix® 10 FPGA Avalon® memory mapped Interface for PCIe with DMA design example fail the link test and the DMA test when using the default setting BAR0?
Description
When the internal DMA Descriptor Controller is enabled, the BAR0 Avalon® memory mapped host interface is not available for general-purpose usage. The DMA Descriptor Controller uses this BAR0 interface through which the host CPU programs in the descriptor table.
The intel_fpga_pcie_link_test user application selects BAR0 as the default setting when it's initially executed. If you forget to change the setting to BAR2, which is where the on-chip memory is attached, then both the link test and the DMA test will fail.
Resolution
You must change the default setting to BAR2 before executing the link test and the DMA test.
See the following execution transcript of the intel_fpga_pcie_link_test user application for steps on how to change the setting to BAR2.
~$ sudo ./intel_fpga_pcie_link_test
FPGA PCIe Link Test
Version 2.0
0: Automatically select a device
1: Manually select a device
> 0
Opened a handle to BAR 0 of a device with BDF 0x1300
0: Link test - 100 writes and reads
1: Write memory space
2: Read memory space
3: Write configuration space
4: Read configuration space
5: Change BAR
6: Change device
7: Enable SRIOV
8: Do a link test for every enabled virtual function
    belonging to the current device
9: Perform DMA
10: Quit program
> 5
Changing BAR...
Enter BAR number (-1 for none):
> 2
Successfully changed BAR!
Updated 3 months ago
Version 2.0
