Knowledge Base Article
Why does the start_basic_test procedure fail when running the GTS JESD204B FPGA IP Design Example on the Agilex™ 5 FPGA hardware?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 25.3, you may observe intermittent failures when running the start_basic_test procedure with the GTS JESD204B FPGA IP Design Example.
Resolution
To work around this problem in the Quartus® Prime Pro Edition Software versions 25.3, download and install the patch below.
After installing the patch, do the following:
- Depending on the data rate, configure the IP ➤ Analog Parameters ➤ Analog Rx ➤ RX Adaptation mode:
- Manual: if data rate <= 7Gbps
- Auto: if data rate > 7Gbps
- Regenerate the design example.
This problem will be fixed in a future release of the Quartus® Prime Pro Edition Software.
Updated 3 months ago
Version 3.0No CommentsBe the first to comment
