Knowledge Base Article
Why does the simulation of the MIPI DSI-2 FPGA IP Design Example fail when the vertical timing (Vtotal) parameter is modified?
Description
Due to a problem in the Quartus® Prime Pro Edition software version 25.1.1 and 25.3, simulation of the MIPI DSI-2 FPGA IP Design Example will fail if vertical timing parameters (VTOTAL) are modified.
This problem occurs because the simulation environment is fixed for a 96-line vertical active region (VTOTAL – VB_END), which causes mismatches with other configurations.
Horizontal timing changes work as long as the parameters remain consistent. This problem affects simulation only; the synthesized IP accepts any valid vertical timing configuration.
Additionally:
- V1B_START must remain at line 0. Changing this parameter results in incorrect output.
- When modifying vertical timing, ensure:
- The active region ends at VTOTAL – 1.
- Adjust V1B and V1S based on blanking starting at line 0.
- This issue affects both simulation and synthesis of the IP.
Resolution
The problem has been fixed starting with Quartus® Prime Pro Edition software version 26.1.
Updated 4 months ago
Version 9.0No CommentsBe the first to comment
