Knowledge Base Article
Why does the Siemens* ModelSim* simulation stop unexpectedly when using the SDI II IP Multi-Rate Parallel loopback without an external VCXO design?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 23.4, the ModelSim* testbench fails when simulating the SDI II Multi-rate Parallel loopback without external VCXO design.
Resolution
To work around this problem, please update the testbench by connecting the gxb_tx_reconfig_xcvr_clk to the tb_test_control_rx_coreclk.
This problem is fixed starting with Quartus® Prime Pro Edition Software version 24.1.
Updated 2 months ago
