Knowledge Base Article
Why does the Serial Lite III Streaming FPGA IP design VHDL simulation fail using QuestaSim and Questa*- FPGA Edition Software?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 23.1, you might observe VHDL simulation failures for the Serial Lite III Streaming IP design with Standard Clocking Mode for the Stratix® 10 L/H-tile devices when using the latest version of QuestaSim and Questa*- FPGA Edition Software.
Resolution
To avoid this simulation failure, you can use the previous Questa Simulator version 2022.1.
This problem will be fixed in a future release of the Quartus® Prime Pro Edition Software.
Updated 3 months ago
