Knowledge Base Article
Why does the Serial Lite III Streaming FPGA IP design simulation fail using Questa*- FPGA Edition Software version 2023.1?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 23.2, you might observe Verilog and VHDL simulation failures for the Serial Lite III Streaming FPGA IP design with Standard Clocking Mode for the Arria® 10 and Cyclone® 10 devices when using the latest version 2023.1 of Questa*- FPGA Edition Software.
Resolution
To avoid this simulation failure, you can use the previous Questa*- FPGA Edition Software version 2022.4.
Updated 2 months ago
