Knowledge Base Article
Why does the rdempty output of my DCFIFO get momentarily deasserted when asserting aclr?
Description
Due to a problem in the Quartus® II software, asserting the aclr input on an empty DCFIFO may cause the rdempty output to be momentarily deasserted. An external register sampling the rdempty output may incorrectly interpret this as a non-empty FIFO.
Resolution
To prevent an external register from incorrectly capturing this glitch, ensure one of the following is true:
- The external register should use the same reset which is connected to the
aclrinput of the DCFIFO megafunction, or - The reset connected to the
aclrinput of the DCFIFO should be asserted synchronously to the clock which drives the external register.
This problem is scheduled to be fixed in a future release of the Quartus II software.
Updated 3 months ago
