Knowledge Base Article
Why does the RapidIO II IP Core transmit when TX digital reset is asserted?
Description
Due to a bug in the RapidIO II IP Core, the transceiver can start transmitting 0xBC characters before TX Digital Reset (tx_digitalreset on Arria® 10, or tx_digitalreset_stat on Stratix® 10) has been de-asserted.
This can cause some link partners to incorrectly detect IDLE1 sequence. The detection of IDLE1 sequence is a defined implementation.
Note that RapidIO II IP Core uses IDLE2 sequence.
Resolution
This problem has been fixed starting in software version 17.0 of the RapidIO II IP core.
Updated 2 months ago
Version 2.0
