Knowledge Base Article
Why does the R-Tile IP for Compute Express Link* (CXL*) Type3 Design Example report the simulation error when selecting DK-DEV-AGI027RBES?
Description
Due to a problem in Quartus® Prime Pro Edition Software version 23.3 and earlier, you will observe a simulation error of R-Tile IP for Compute Express Link* (CXL*) Type3 Design Example when selecting DK-DEV-AGI027RBES (RevB B0 Dev kits).
The error message will be similar to the one shown below:
Error-[MPD] Module previously declared
  The module was previously declared at:
  "xxxx/intel_rtile_cxl_top_0_ed/hardware_test_design/common/mc_top/emif_ip/emif/altera_emif_arch_fm_191/sim/altera_emif_arch_fm_bufs.sv",
  18
  It is redeclared later at:
  "xxxx/intel_rtile_cxl_top_0_ed/hardware_test_design/common/mc_top/emif2_ip/emif2/altera_emif_arch_fm_191/sim/altera_emif_arch_fm_bufs.sv",
  18: token is 'altera_emif_arch_fm_bufs'
  module altera_emif_arch_fm_bufs #(
Resolution
This problem is scheduled to be fixed in a future release of the Intel® Quartus® Prime Pro Edition Software.
To work around this problem, refer to the following modification of the file list:
1. Open /sim_filelist "ed_ip_filelist.f".
2. Comment out all lines related to “emif2” and run the simulation.
Updated 3 months ago
Version 2.0
