Knowledge Base Article
Why does the R-Tile Avalon® Streaming Intel® FPGA IP for PCI Express fails in hardware when using the Intel® Quartus® Prime Pro Edition Software Programmer v21.4 and v22.1?
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software version 21.4 and 22.1, you might experience functional problems in designs that include an instance of the R-Tile Avalon® Streaming Intel® FPGA IP for PCI Express.
The functional problems only happen when loading a SRAM Object File (.sof) using an Intel® Quartus® Prime Software Programmer version that doesn't match with the Intel® Quartus® Prime Software version used to generate the .sof file. Use the following table as reference:
Intel® Quartus® Prime Software Programmer versionIntel® Quartus® Prime Pro Edition Software versionResult
21.421.4No functional problems
21.422.1Potential functional problems
22.121.4Potential functional problems
22.122.1No functional problems
Resolution
To work around this problem, load the SRAM Object File (.sof) with the Intel® Quartus® Prime Software Programmer version that matches the Intel® Quartus® Prime Software version used to generate the .sof file
Updated 3 months ago
Version 2.0
