Knowledge Base Article
Why does the R-Tile Avalon® Streaming FPGA IP for PCI Express* example driver fail to install correctly? It can't be installed in CentOS* 8?
Description
When trying to install the example driver generated by the R-Tile Avalon® Streaming FPGA IP for PCI Express* Design Example in CentOS* 8, error messages like those shown below will be seen:
error: macro "access_ok" passed 3 arguments, but takes just 2
if(! access_ok(VERIFY_WRITE, buf, sizeof(buf))) {
error: ‘access_ok’ undeclared (first use in this function)
Resolution
A Linux* kernel mismatch causes these errors. The following steps can help to resolve this issue:
- In intel_fpga_pcie_chr.c, delete the first argument (VERIFY_WRITE/VERIFY_READ) of function "access_ok"
- In intel_fpga_pcie_ioctl.c, replace the name of function "dma_zalloc_coherent" with "dma_alloc_coherent"
- In intel_fpga_pcie_ioctl.c, in "access_ok(uarg, sizeof(uarg))", change the argument uarg to (void__user *)uarg
- In intel_fpga_pcie_setup.c, replace the name of function "ioremap_nocache" with "ioremap_cache"
- In intel_fpga_pcie_setup.c, comment the line of codes "MODULE_SUPPORTED_DEVICE("Intel(R) Stratix 10 FPGA")"
The driver can be installed successfully and works correctly after these modifications.
This problem isn't currently scheduled to be fixed.
Updated 3 months ago
