Knowledge Base Article
Why does the Quartus II software give a fatal error after adding post-fit nodes in the SignalTap II Logic Analyzer?
Description
Due to a problem in the Quartus® II software version 12.1 and later, you may see a fatal error after adding post-fit nodes to the SignalTap II Logic Analyser in your Stratix® V design.
Resolution
To work around this problem, delete the db and incremental_db directories.
This problem is fixed beginning with the Quartus II software version 13.1.
Updated 21 days ago
Version 2.0
