Knowledge Base Article
Why does the Quartus II software fitter report sometimes show different PLL output counter ordering than what I have used in my design?
Description
When you instantiate a PLL in Arria® II, Cyclone® III, Cyclone IV, Stratix® III, and Stratix IV devices, you may find wire_pll1_clk[X] does not map to counter[X]. For example, you may find wire_pll1_clk[3] does not use C3 in the fitter report. That is expected behavior because the fitter will place PLL output clocks according to the required routing resources for the clock network.
If you want wire_pll1_clk[X] to dynamically phase shift, you will need to select the phasecounterselect for C[X] counter according to “Phase Counter Select Mapping” table in the device handbook. The phasecounterselect will be consistent with the RTL code, the physical mapping to output counter locations by the fitter is irrelevant.
Updated 3 months ago
