Knowledge Base Article
Why does the Quartus® Prime Pro Edition Software version 24.1 observe 17 clock cycles when using the Generic Serial Flash Interface IP(GSFI IP)?
Description
This problem is caused by 2 modules in the GSFI IP: the if_ctrl (interface control) module, which is used to interface to the QSPI flash, and the cmd (command) module, which is used to generate the flash command.
The additional flash clock only impacts read operations on the flash, which are read data or read register operations. It does not impact write operations.
Resolution
To workaround this problem, use the following patch in the Quartus® Prime Pro Edition software version 21.4.
Updated 7 hours ago
Version 3.0No CommentsBe the first to comment
