Knowledge Base Article
Why does the qmegawiz add areset and locked ports to my ALTPLL megafunction when running in silent mode?
Description
Due to a problem in the Quartus® II software, using the qmegawiz command-line executable to generate an ALTPLL megafunction may add or remove unwanted ports to your Verilog HDL or VHDL output file, including areset and locked ports.
Resolution
To work around this problem, use the MegaWizard™ Plug-In Manager with the GUI.
Updated 2 months ago
Version 2.0
