Knowledge Base Article
Why does the Print and Page Setup windows fail to pop out in the Intel® Quartus® Prime Pro Edition software?
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition software version 19.1 and earlier, you may see that the printing function is not working. File > Print and File > Page Setup will not pop out when you click on it. This happened on all Windows* OS.
Resolution
To work around this problem, save the file as Portable Document Format (PDF) by File > Print Preview > Print. You can print the file using other PDF software.
Updated 3 months ago
Version 2.0
