Knowledge Base Article
Why does the PLL fail to switch the input reference clock when using the Manual Switchover mode in Arria® V, Cyclone® V, and Stratix® V devices?
Description
Due to a problem with the Intel® Quartus® Prime Software version 17.1 and earlier,  the phase-locked loop (PLL) might fail to switch the reference clock input when using the Manual Switchover mode in Arria® V, Cyclone® V, and Stratix® V devices.  When this problem occurs, PLL always selects one of two reference clocks regardless of the status of extswitch signal.
You can know whether this problem occurs or not from the fitter report.  See PLL Refclk Select under PLL Usage Summary in the fitter report.  There are PLL Reference Clock Input 0 source and PLL Reference Clock Input 1 source.  If the problem occurs, the same clock signal is connected to both of them incorrectly.  If the problem doesn't occur, two different clock signals are connected to them respectively.
Resolution
Changing the locations of two reference clock input pins might work around this problem:
  1. Exchange two reference clock input pin locations
    • (Example) When connecting clock_a signal to clk0 input and clock_b signal to clk1 input currently, connect clock_a signal to clk1 input and clock_b signal to clk0 input
  2. Change one or both of two reference clock input pin locations
    • (Example) When connecting clock_a signal to clk0 input and clock_b signal to clk1 input currently, connect clock_b siganl to clk3 input
If these workarounds do not improve the problem or you can't change the reference clock input pin locations,  file an Intel® Premier Support case.
Updated 11 months ago
Version 3.0
