Knowledge Base Article
Why does the PCIe x8 core's RX buffer credit allocation change values after I Finish generating my PCIe core in the Qsys system?
Description
You may observe after reopening the PCIe® core in your Qsys system, that the Buffer Configuration credit allocations are diffent than the configured values.  This is observed when using a x8 configuration.
This is a known bug scheduled to be fixed in a future release of the Quartus® II software.
Resolution
The workaround for this issue is to change the default specified values in the Qsys system top-level RTL file, specifically the PCIe instantiation parameter definition.  This is found in <qsys_system_name>.v file and in pcie instantiation template <qsys_system_name>_pcie_hard_ip_0.
Default defined in Qsys PCIe instantiation:
        .vc0_rx_flow_ctrl_posted_header      (17),
        .vc0_rx_flow_ctrl_posted_data        (91),
        .vc0_rx_flow_ctrl_nonposted_header  (20),
        .vc0_rx_flow_ctrl_nonposted_data    (0),
        .vc0_rx_flow_ctrl_compl_header      (0),
        .vc0_rx_flow_ctrl_compl_data        (0),
Change the above values to those observed in MegaWizard™ Plug-In Manager PCIe core GUI for the configuration you are using.
Updated 2 months ago
Version 2.0
