Knowledge Base Article
Why does the o_rx_pcs_ready signal fail to assert during a simulation of the F-Tile Ethernet Multirate Intel® FPGA IP Dynamic Reconfiguration when the startup profile is using a subset of the FGT PMAs within the reconfiguration group.
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software version 22.1, o_rx_pcs_ready will fail to assert during simulation of the F-Tile Ethernet Multirate Intel® FPGA IP Dynamic Reconfiguration Design Example when the startup profile is using a subset of the FGT PMAs within the reconfiguration group.
For example, if using the F-Tile Ethernet Multirate Intel® FPGA IP with the 100GE-4 Reconfigurable reconfiguration group and using the 100GE-2 profile as your startup profile (the startup profile is using 2 out of 4 FGT transceivers in the reconfiguration group).
Resolution
To work around this problem in simulation, ensure that the startup profile uses a superset of FGT transceivers for all the dynamic reconfiguration profiles in the design.
This problem is scheduled to be fixed in a future release of the Intel® Quartus® Prime Pro Edition Software.
Updated 2 months ago
Version 2.0
