Knowledge Base Article
Why does the "o_rx_error" port of the E-Tile Hard IP for Ethernet Hard Intel® FPGA IP core not reflect oversized frames in transmission?
Description
Due to a fault in the 100G E-Tile Hard IP for Ethernet Hard Intel® FPGA IP core RX status detection logic, you might observe oversized frames ( default maximum frame size in IP setting is 1518), fail to cause the relative bit of port o_rx_error to assert to reflect oversized frame behavior.
Resolution
There is no plan to fix this issue in future IP release. You can use statistic register(0x924/0x925) to monitor whether there is oversized frame in transmission.
Updated 3 months ago
