Knowledge Base Article
Why does the Nios® II build flow report Unable to determine program-size on Windows WSL?
Description
Due to a problem in the nios2-elf-stackreport utility in the Intel® Quartus® Prime Pro Edition software version 19.3, the nios2-elf-stackreport utility does
not report the program size or the stack heap size.
Resolution
To work around this problem, edit the nios2-stackreport.pl wrapper to add missing .exe suffix in tool names.
Modify file:
/nios2eds/bin/nios2-stackreport.pl
line 47: “nm” to “nm.exe”
line 48: “size” to “size.exe”
This problem is fixed beginning with the Intel® Quartus® Prime software version 19.4.
Updated 3 months ago
