Knowledge Base Article
Why does the Multi-Channel DMA FPGA IP for PCI Express* stall or stop operating when the Q_SIZE parameter is configured to 0x10?
Description
Due to a problem in the Quartus® Prime Pro Edition software version 24.2 and later, the Multi-Channel DMA FPGA IP for PCI Express* may stall or cease operation when the Q_SIZE parameter is set to 0x10.
Resolution
The recommended workaround is to limit Q_SIZE to 0xF. If your design requires a Q_SIZE of 0x10, upgrade to the Quartus® Prime Pro Edition software version 25.3.1, regenerate the Multi-Channel DMA FPGA IP for PCI Express, and recompile the design to ensure the fix takes effect.
Updated 3 months ago
Version 3.0
