Knowledge Base Article
Why does the Multi Channel DMA FPGA IP for PCI Express* Design Example for F-Tile variant fail to simulate when using the Cadence Xcelium* simulator?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 22.1 to 23.3, the Multi Channel DMA FPGA IP for PCI Express* Design Example for F-Tile variant fails to simulate when using the Cadence Xcelium* simulator.
Resolution
To work around this problem in simulation,  use the below command to run with the Cadence Xcelium simulation:
For Quartus® Prime Pro Edition Software version 23.3
sh xcelium_setup.sh USER_DEFINED_VERILOG_COMPILE_OPTIONS="+define+RTLSIM\ +define+SSM_SEQUENCE\ -sv" USER_DEFINED_ELAB_OPTIONS="-warn_multiple_driver\ -timescale\ 1ns/1ps" USER_DEFINED_SIM_OPTIONS="" | tee simulation.log
For the Quartus® Prime Pro Edition Software version 22.1 to 23.2
sh xcelium_setup.sh USER_DEFINED_VERILOG_COMPILE_OPTIONS="+define+RTLSIM\ +define+SSM_SEQUENCE\ -sv" USER_DEFINED_ELAB_OPTIONS="-timescale\ 1ns/1ps" USER_DEFINED_SIM_OPTIONS="" | tee simulation.log
This problem is fixed in Quartus® Prime Pro Edition Software version 23.4.
Updated 11 months ago
Version 3.0
