Knowledge Base Article
Why does the ModelSim*-Intel® FPGA software simulator generate an error while simulating the Intel Agilex® 7 FPGA EMIF IP design example with an Efficiency monitor enabled?
Description
While running the register transfer level (RTL) simulation for the Intel Agilex® FPGA EMIF IP design example with Efficiency monitor enabled, errors occur with the following error message:
Error (vsim-8604) ../ip/ed_sim/ed_sim_dut/altera_amm_effmon_191/sim/altera_amm_effmon_single_top.sv(246): NaN (not a number) resulted from a division operation
Resolution
This issue has been fixed in the Intel® Quartus® Prime Pro Edition Software version 21.2 or later versions.
Updated 3 months ago
