Knowledge Base Article
Why does the LPM_ADD_SUB IP core generate incorrect results?
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software, you might get incorrect results in hardware when using the LPM_ADD_SUB IP core for Intel® Stratix® 10 devices. The problem occurs only when a pipeline stage of greater than 1 is used. The simulation yields correct results.
Resolution
To work around the problem, use the pipeline stage of 1 or 0.
Updated 2 months ago
Version 2.0
