Knowledge Base Article
Why does the local_cal_success go high but local_init_done stay low during RTL simulation for the hard memory controller?
Description
When running an RTL simulation for the UniPHY-based hard memory controller in Arria® V or Cyclone® V device, you may find local_cal_success go high but local_init_done stay low. The local_init_done signal is driven by the hard memory controller based on the internally synchronized version of the afi_cal_success input. The local_init_done and local_cal_success signals should have the same behavior. However, they may have different behaviors if the the clock input or reset input for the multi port front-end (MPFE) is not correctly connected.
Resolution
Make sure the MPFE clock and reset ports are properly connected.
Related Articles
Updated 2 months ago
Version 2.0
