Knowledge Base Article
Why does the JESD204C Intel® FPGA IP Example Design intermittently fail to operate correctly when performing repetitive resets tests in Intel® Stratix® 10 MX, Intel® Stratix® 10 TX or Intel Agilex® devices?
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software versions 19.2 to 20.1, the JESD204C Intel® FPGA IP Example Design may intermittently fail to operate correctly when performing repetitive resets tests when using Intel® Stratix® 10 TX, Intel® Stratix® 10 MX or Intel Agilex® 7 devices.
This is due to the possibility of sporadically triggering a short assertion of RX gearbox FIFO RD EMPTY during repetitive resets test.
Resolution
To avoid failure, it is recommended to delay the 1st FIFO read operation to give an extra link clock cycle of protection to FIFO RD EMPTY.
A patch is also available to fix this problem for the Intel® Quartus® Prime Pro Edition Software versions 19.2, 19.3, 19.4, and 20.1.
Download and install the respective patch from the appropriate link below.
Download patch Intel® Quartus® Prime 19.2 Patch 0.19 for Windows (.exe)
Download patch Intel® Quartus® Prime 19.2 Patch 0.19 for Linux (.run)
Download the Readme for Intel® Quartus® Prime 19.2 Patch 0.19 (.txt)
Download patch Intel® Quartus® Prime 19.3 Patch 0.49 for Windows (.exe)
Download patch Intel® Quartus® Prime 19.3 Patch 0.49 for Linux (.run)
Download the Readme for Intel® Quartus® Prime 19.3 Patch 0.49 (.txt)
Download patch Intel® Quartus® Prime 19.4 Patch 0.26 for Windows (.exe)
Download patch Intel® Quartus® Prime 19.4 Patch 0.26 for Linux (.run)
Download the Readme for Intel® Quartus® Prime 19.4 Patch 0.26 (.txt)
Download patch Intel® Quartus® Prime 20.1 Patch 0.12 for Windows (.exe)
Download patch Intel® Quartus® Prime 20.1 Patch 0.12 for Linux (.run)
Download the Readme for Intel® Quartus® Prime 20.1 Patch 0.12 (.txt)
This problem is fixed starting with Intel Quartus Prime Pro Edition Software version 20.2.
