Knowledge Base Article
Why does the JESD204B Example Design fail to generate in simplex transmitter mode?
Description
In the JESD204B example design targetting Intel® Arria® 10 or Intel® Stratix® 10 devices, the ATX PLL component shares the same reference clock frequency with the CDR clock frequency.
For duplex mode (Data path: Duplex), you can select a valid reference clock from the PLL/CDR Reference Clock Frequency drop-down menu in the IP parameter editor.
For simplex TX mode (Data path: Transmitter), the drop-down menu is not available for selection. The example design generation will take the previous valid reference clock frequency from the drop-down. This may cause an error during example, design generation.
Resolution
To avoid this error for simplex TX example design generation, follow the sequence below when configuring the JESD204B IP parameters:
Enter the desired Data rate.
Choose a valid reference clock from PLL/CDR Reference Clock Frequency drop-down**.
Select Data path: Transmitter
Configure the rest of the parameters.
** Please refer to the Intel Arria® 10/Intel® Stratix® 10 Device Datasheet for a valid range of reference clock frequency for the ATX PLL.
This problem is fixed starting with Intel® Quartus® Prime Pro Software version 17.1
Updated 2 months ago
Version 2.0
