Knowledge Base Article
Why does the interface 1 port simulate incorrectly when the abstract phy simulation model is used in the Intel® Arria® 10 DDR4 Ping Pong PHY IP?
Description
When using the Intel® Quartus® Prime software version 17.1.2 or earlier, you may see the interface 1 port simulate incorrectly when the Intel Arria® 10 DDR4 Ping Pong PHY IP is configured with both the Abstract phy for simulation option and the Write DBI option enabled.
Note that the interface 0 port simulates correctly.
Resolution
This problem is fixed in the Intel® Quartus® Prime software version 18.0 or newer.
Updated 1 month ago
Version 2.0
