Knowledge Base Article
Why does the Intel FPGA VIP Suite Deinterlacer II IP product poor deinterlacing quality?
Description
Due to a problem with the Quartus® Prime v16.1 of VIP Suite Deinterlacer II IP, when using video-over-firm cadence detection and correction algorithm, you may experience poor deinterlacing quality and that is because of a swapped f0/f1 issue.
Resolution
The workaround in v16.1 is to create a custom block prior to the deinterlacer II IP to toggle bit 2 of the interlaced nibble of incoming Avalon-ST video control packets. This issue is fixed starting in Quartus® Prime v17.0.
Updated 1 month ago
Version 2.0
