Knowledge Base Article
Why does the Intel Agilex® 7 F-Tile SDI II FPGA IP design example fail to compile at the Support-Logic Generation stage?
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software v21.4, the Intel Agilex® 7 F-Tile SDI II FPGA IP design example will fail at the Support-Logic Generation stage during compilation with the following error message:
Error(21842): Support logic cannot be generated because IP components used in the design have conflicting settings.
Resolution
A patch is available to fix this problem for the Intel® Quartus® Prime Pro Edition Software version 21.4.
Download and install Patch 0.01 from the following links:
This problem is being fixed starting with the Intel® Quartus® Prime Pro Edition Software version 22.1.
Updated 8 months ago
Version 4.0
