Knowledge Base Article
Why does the Intel® Stratix® 10 PCIe* Avalon® -MM Hard IP fail to respond to inbound memory read TLPs with the No Snoop bit set?
Description
Due to a limitation of the Intel® Stratix® 10 PCIe* Avalon® -MM Bridge, inbound memory read TLPs with the No Snoop bit set will be dropped and no completions returned, which can cause system failure.
Resolution
To work around this problem, constrain the link partner to only send the Memory read TLPs without the No Snoop bit set to the Intel® Stratix® 10 PCIe* Avalon® -MM Hard IP.
Updated 3 months ago
