Knowledge Base Article
Why does the Intel® L-tile and H-tile Avalon® Streaming and Avalon® Memory Mapped IP for PCI Express* observe correctable errors/link down train when operating in Gen3 Root Port mode?
Description
When using the Intel® L-tile and H-tile Avalon® Streaming and Avalon® Memory Mapped IP for PCI Express* in Gen3 Root Port mode, correctable errors or link down training may be observed due to sub-optimal preset bit settings for PCIe* Upstream Port (USP)/Downstream Port (DSP) Gen3 Root Port IP on both H tile and L tile.
Resolution
No work around to this problem exists in Intel® Quartus® Prime software versions 20.2 and earlier.
This problem has been fixed in Intel® Quartus® Prime software versions 20.3 and later.
If upgrading from an earlier version of the software, the IP should be generated from clean to avoid inporting the earlier sub-optimal settings.
Updated 3 months ago
