Knowledge Base Article
Why does the In-System Programmability (ISP) Clamp feature not work when programming an Intel® MAX® 10 device with a Jam STAPL Byte Code (.jbc) file?
Description
Due to a problem in the Intel® Quartus® Prime Software Programmer version 19.3 and earlier, you might  see the ISP Clamp feature not working when programming an Intel® MaAX® 10 device with a Jam STAPL Byte Code (.jbc) file.
Resolution
To work around this problem, perform the following steps:
  1. Use the Assignment Editor to add an In-System Programming Clamp State assignment with the required clamp value and compile your design.
  2. In the Intel® Quartus® Prime Software Programmer, add your compiled Programming Object File (.pof) file.
  3. Check all the Program/Configure and ISP CLAMP options.
  4. Check the option Enable real-time ISP to allow background programming.
  5. Generate the Jam STAPL Byte Code (.jbc) file through the menu File > Create JAM, JBC, SVF or SC File.
  6. Program your device with the generated Jam STAPL Byte Code (.jbc) file. Ensure that the Enable real-time ISP to allow background programming option is disabled.
Updated 2 months ago
Version 2.0
