Knowledge Base Article
Why does the HPS Flash Programmer (quartus_hps) fail to access QSPI flash in XIP mode?
Description
Due to a problem in the Intel® Quartus® Prime Design Software version 17.0 and earlier, the HPS Flash Programmer (quartus_hps) may fail to access Quad Serial Peripheral Interface (QSPI) flash device that has been put into Execute-In-Place (XIP) mode.
The following error messages may be seen:
Quad SPI Flash silicon ID is 0xFFFFFFFF
Error: Not able to map flash ID from flash database
Resolution
This problem is fixed beginning with the Intel® Quartus® Prime Design Software version 17.1.
The HPS Flash Programmer in Intel® Quartus® Prime Design Software version 17.1 introduces a new argument named exit_xip that exists the QSPI flash device from XIP mode when user specify a non-zero value for the argument.
For example, run quartus_hps -c <cable> -o <operation> --exit_xip=0x80.
Updated 1 month ago
Version 3.0
