Knowledge Base Article
Why does the host fail to load the raw binary file(rbf) via Intel® Arria® 10 PCIe* Hard IP for the CvP initialization mode operation?
Description
Due to the limitation of the Intel® Arria® 10 PCIe* Hard IP, it can only receive the raw binary file(rbf) from the host successfully via BAR0 when the memory transaction mode is preferred for the CvP initialization opereation. If other BARs are enabled other than the BAR0, the host may fail to load raw binary file(rbf) via Intel® Arria® 10 PCIe* Hard IP successfully.
Resolution
To work around this problem, enable BAR0 when using memory transaction mode to load the raw binary file(rbf) for the CvP initialization operation.
Updated 3 months ago
Version 2.0
