Knowledge Base Article
Why does the High Speed Reed Solomon FPGA IP Core generate an incorrect set of check symbols for my data?
Description
Due to a problem with the RTL source generation of the High Speed Reed Solomon FPGA IP Core, if the 'Hyper-optimization' parameter is set to 'High' the IP will generate an incorrect set of check symbols for the incoming data payload.
Resolution
To work around this problem, set the 'Hyper-optimization' parameter to 'Low'.
Updated 2 months ago
