Knowledge Base Article
Why does the Hard IP for PCI Express 128-bit Avalon-MM TX interface not transmit packets in simulation?
Description
When simulating the Hard IP for PCI Express® 128-bit Avalon-MM interface in the Quartus® II software version 14.0 and earlier, the device under test (DUT) is not able to transmit any packets from the Avalon-MM bus to the PCIe link.
This problem is caused by the incorrect width declaration of control signals in the transmit data path. The control signals are declared as 5-bits, but only 4-bits are driven in the testbench. The most significant bit is not driven and becomes "x" in simulation.
Resolution
To work around this problem, follow the steps below:
- Open the file altpciexpav128_cr_rp.v
- Find the lines
- wire [4:0] tx_low64_fifo_wrusedw
- wire [4:0] tx_hi64_fifo_wrusedw
- Change the lines to
- wire [3:0] tx_low64_fifo_wrusedw
- wire [3:0] tx_hi64_fifo_wrusedw
The problem is scheduled to be fixed in a future release of the Quartus® II software.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
