Knowledge Base Article
Why does the H-Tile Hard IP for Ethernet FPGA IP Core failed to generate the design example?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 19.2, the H-Tile Hard IP for Ethernet FPGA IP Core will fail to generate a design example if the Target Development Kit is set to NONE.
Resolution
To work around this problem in the Quartus® Prime Pro Edition Software version 19.2, set the Target Development Kit to the kit featuring the device closest to your project's device.
This problem is fixed starting with the Quartus® Prime Pro Edition Software version 19.3.
Updated 1 month ago
