Knowledge Base Article
Why does the GTS Serial Lite IV IP design example fail VHDL simulation using the Riviera-PRO™ simulator?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 24.3, you will observe the GTS Serial Lite IV IP design example fail VHDL simulation using the Riviera-PRO simulator.
Resolution
To work around the above problem, you can apply either of the following methods:
  1. Perform Verilog simulation, or
  2. Use a different simulator.
Updated 11 months ago
Version 3.0
