Knowledge Base Article
Why does the GTS JESD204B IP Design Example in Dual Simplex PHY only mode remain in the reset state when simulating with the VCSMX simulation tool?
Description
Due to a problem in the 24.3.1 release of the Quartus® Prime Pro Edition software, the tx_out_of_reset output port is unconnected in the GTS JESD204B IP Design Example in Dual Simplex PHY only mode. This error causes the system to be unable to release both the link reset and frame reset. As the IP is in reset, the IP simulation fails to start.
Resolution
To work around this problem in version 24.3.1 of the Quartus® Prime Pro Edition software, connect u_jesd_gts_ed_qsys_RX_TX|jesd_gts_ss_rx_tx|ds_group_jesd204b|tx_phy_ds_group_0_inst0_auto_jesd204_tx_out_of_reset (export output port to top level) to wire named tx_out_of_reset[0] in top level wrapper (intel_jesd204b_gts_ed_RX_TX.sv)
Additionally, Altera recommends installing the patch in the Quartus® Prime Pro Edition Software version 24.3.1.
After installing the patch, regenerate the GTS JESD204B IP Design Example and run the simulation.
This problem is fixed in version 25.1 of the Quartus® Prime Pro Edition Software.
Updated 4 months ago
Version 4.0
