Knowledge Base Article
Why does the GTS HDMI IP Design Example with Integrated Transceiver without Dual Simplex mode fail to compile?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 24.2, the GTS HDMI IP Design Example with Integrated Transceiver, not in Dual Simplex mode, will fail to compile during the fitter stage when using the Agilex™ 5 FPGA devices.
Resolution
This problem is fixed beginning with version 24.3 of the Quartus® Prime Pro Edition Software.
Updated 3 months ago
Version 2.0
