Knowledge Base Article
Why does the GTS HDMI IP Design Example fail to compile during the analysis and synthesis stage when the Relative Offset has been set to a nonzero value of the HDMI RX in the Dual Simplex Assignment Editor?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 24.2, the Relative Offset for the GTS HDMI IP with Dual Simplex configurations in the Agilex™ 5 FPGA devices is limited to a value of "0".
The following error will be seen if a non-zero relative offset value is used.
Error(13076): The node "u_DS_GROUP_0|hdmi_tx_inst0__hdmi_tx__u_tx__direct_phy_tx__g1_period_n_period_sys_lsqb_0_rsqb__period_n_channel_superset_ip_inst__n_channel_superset_top_wrapper__hal_top_wrapper_inst__hal_top_ip__one_lane_inst_0__one_lane_hal_top_p0__phy_hal_top_inst__phy_hal_top__phy_hal_coreip_inst__ch4_phy_inst__x_std_sm_flux_ingress_0" has multiple drivers.
  Error(20073): "non-tri-state driver "u_DS_GROUP_0|hdmi_tx_inst0__hdmi_tx__u_tx__direct_phy_tx__g1_period_n_period_sys_lsqb_0_rsqb__period_n_channel_superset_ip_inst__n_channel_superset_top_wrapper__hal_top_wrapper_inst__hal_top_ip__one_lane_inst_0__one_lane_hal_top_p0__phy_hal_top_inst__phy_hal_top__phy_hal_coreip_inst__ch4_phy_inst__x_std_sm_flux_ingress_0"" is one of the multiple drivers.
  Error(20073): "non-tri-state driver "u_DS_GROUP_0|dstool__tennm_sm_flux_ingress_ch1_0"" is one of the multiple drivers.
  Error(20073): "non-tri-state driver "u_DS_GROUP_0|dstool__tennm_sm_flux_ingress_ch2_0"" is one of the multiple drivers.
  Error(20073): "non-tri-state driver "u_DS_GROUP_0|dstool__tennm_sm_flux_ingress_ch3_0"" is one of the multiple drivers.
Resolution
This problem is fixed beginning with version 24.3.1 of the Quartus® Prime Pro Edition Software.
Updated 18 days ago
Version 2.0
