Knowledge Base Article
Why does the Generic Serial Flash Interface (GSFI) Intel® FPGA IP fail to write certain byte into the flash?
Description
Due to the limitation in the Intel® Quartus® Prime Software version 19.1 and earlier, certain byte unable to write into the flash due to unsupported byteenable patterns/cases when the GSFI IP is connected to a 64-bit Avalon master and burst data transfer is being used.
Below are the unsupported GSFI IP byteenable patterns/cases:
- 4'b0110
- 4'b0111
- 4'b1110
Resolution
To work around this problem, either send data in 32-bit width or avoid using the unsupported byte enable patterns/cases.
This problem is fixed starting with the Intel® Quartus® Prime Standard Edition Software version 20.1.
Updated 3 months ago
