Knowledge Base Article
Why does the generation of the F-Tile DisplayPort FPGA IP Design Example with the simulation option enabled fail?
Description
Due to a problem in the Quartus® Prime Pro Edition Software v23.4 and earlier, the F-Tile DisplayPort FPGA IP Design Example with simulation enabled cannot be generated successfully.
Resolution
Do not select the simulation option when generating the F-Tile DisplayPort FPGA IP Design Example. The design example can be generated successfully without the simulation option.
This problem has been fixed starting in version 24.1 of the Quartus® Prime Pro Edition Software.
Updated 2 months ago
Version 2.0
