Knowledge Base Article
Why does the fitter report errors when I recompile my previous working PCIe design in the Quartus® II software version 10.1?
Description
Due to a problem in the Quartus® II software version 10.1, some PCIe designs that worked in previous versions of the Quartus II software might result in the following fitter errors in v10.1:
Error: Quartus II software cannot combine the following Calibration block(s) due to inconsistent parameters and/or input connections.
Error: Input port "TEST_CTRL" must be driven by the same source.
Resolution
A patch is available to fix this problem for the Quartus® II software version 10.1. Download and install patch 0.30:
- Quartus II software version 10.1 Patch 0.30 for Windows (.exe)
- Quartus II software version 10.1 Patch 0.30 for Linux (.tar)
- Readme for the Quartus II software version 10.1 Patch 0.30 (.txt)
This problem is scheduled to be fixed in a future release of the Quartus® II software.
Updated 2 months ago
