Knowledge Base Article
Why does the FIR II Intel® FPGA IP fail to generate in the Intel® Quartus® Prime Pro Edition Software version 22.1?
Description
The FIR II Intel® FPGA IP generates multiple Avalon streaming parameters when upgrading to the Intel® Quartus® Prime Pro Edition Software version 22.1.
Error: ip_firII.fir_compiler_ii_0: There is an unknown error
Error: ip_firII.fir_compiler_ii_0: Output Bit Width should be greater than 1
Error: ip_firII.fir_compiler_ii_0: Port ast_sink_data is not fully defined after elaboration
Error: ip_firII.fir_compiler_ii_0: Port ast_source_data is not fully defined after elaboration
Error: ip_firII.fir_compiler_ii_0.avalon_streaming_sink: data width (-1) must be a multiple of bitsPerSymbol (8)
Error: ip_firII.fir_compiler_ii_0.avalon_streaming_sink: Signal ast_sink_data[-1] of type data must have width [1-8192]
Error: ip_firII.fir_compiler_ii_0.avalon_streaming_source: Signal ast_source_data[-1] of type data must have width [1-8192]
Error: ip_firII.fir_compiler_ii_0.avalon_streaming_source: "Data bits per symbol" (dataBitsPerSymbol) 0 is out of range: 1-131072
These errors only appear in Windows*.
Resolution
To work around this problem when using the Intel® Quartus® Prime Pro Edition Software version 22.1 of the FIR II Intel® FPGA IP, install patch 0.16
