Knowledge Base Article
Why does the F-Tile Triple-Speed Ethernet FPGA IP Design Example enable RX auto adaptation?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 23.4, RX auto adaptation is enabled automatically in the design example generated by the F-Tile Triple-Speed Ethernet FPGA IP.
According to AN 969: F-Tile PMA Tuning Guidelines, the following are the guidelines for RX auto adaptation:
"For lower data rate applications which usually use unscrambled data, for example CPRI 6 Gbps and lower, DisplayPort less than 8 Gbps, you can disable auto adaptation. This is because, for these unscrambled data applications, DFE may have a challenge to converge and thus introduce errors or may result in performance degradation if auto adaptation is ON."
Resolution
To work around this problem, modify the Quartus® Settings File (.qsf) file of the generated design example to bypass RX auto adaptation according to “FGT PMA Settings” section on F-Tile Architecture and PMA and FEC Direct PHY IP User Guide.
This problem has been fixed starting in version 24.1 of the Quartus® Prime Pro Edition Software.
Updated 2 months ago
Version 2.0
